31cc7
Active member
If I turn the mixer on, channels 2, 4, 6 are almost dead silent. Only when I overdrive them hard, they "pop up" and work fine when I turn the signal down. When I stop sending them music for a couple of minutes they "die" again and I have to overdrive them to make them work again.
So the 3 boards out of 4 have this issue and all three on the same right channel. That feels like maybe something to do with capacitors? As if the audio signal is low these can't get charged enough and the overdrive "jump starts" the circuit?
Could this be some sort of damage I caused by powering it with weak PSU in the beginning?
Other than that everything works great.
