horvitz
So, good progress is being made. Fired up the whole thing today. To pick up a previous topic, we were wondering about how much noise I'd wind up with if I float the Lo signal on my input. The answer is some..
Just generally looking at peak levels on the meters in PT (I know not really accurate, but it's a good enough measure), I get:
Just 2-ACA-Bo : -95db
2-ACA-Bo + 4-ACA : -85db
Input cables hooked up : -65db
As I have it right now, the only path to ground for the audio on the input side is via the 100k on the input to the 4-ACA. If I run that straight to the chassis, I wind up with about -70db. That's better, but I still hear a very slight hum if I crank the output. I guess maybe that's what I live with? I'm not sure how else I could configure it.
Speaking of that 100k, one thing that I noticed in my checking of grounds is that the 100k on the input to the 2-ACA isn't really doing much. On the front side, it's connected to the ground on the output of the 4-ACA, which goes to the chassis. On the back, it's also connected to the chassis. So in my configuration, that resistor is rendered ineffective. Nothing to really worry about I would gather, but just a note around the way I'm using it here.
Bug hunting aside, the thing works great! I'm really happy with how it all turned out. Did a VERY quick mix on something here and I love it
Thanks Jeff for making all this available!
