SIXTYNINER
Tubemooley said:I'll weigh in briefly on one of those questions. To get balanced line in, you can do transformer-balanced input with a line-level transformer. Or you can do what's called a balanced-transformerless amplifier or BTA. You can send a balanced signal into one DOA and then the output of that DOA can dump onto your summing bus. Go to Jeff's website and go to the documents section. Look for the API doc which shows different configurations of the 2520 amplifier. One of them is the BTA. DW.
Also take a look at the "API 325 Operation Ref." near the bottom right of the ref docs page. They have a much more clear description of a Balanced Differential Input Amplifier which is more or less the circuit that was used in the consoles. It is the same circuit that Tubemooley was referring too. He is psycho BTW and probably off his meds, so be careful!horvitz said:...I had a look at the BTA layout in the doc on Jeff's web site, but it's a little hard to see so I'm not sure what to make of it.
I am not exactly sure what they are doing on the 1608's. I would gather it is quite a bit different than the old desks. It is for a different purpose but could possibly work.Johndcx said:The fader can be a pot like the one one the monitor out on the new 1604s?
jsteiger said:As far as floating or connecting the Lo side to ground, it will probably be gear dependent. I do this with a few special patchbay cables that have pin 3 or Lo floating. By using a standard patch cable I am connecting pin 3 to ground within the PB jack.
Also, FWIW, within my console, the shield of almost every cable run is floating at the source and connected at the destination.
That would be a big 10-4 good buddy. Psycho? That's an understatement. But I am taking my meds. I just wish my tin foil helmet did a better job of keeping those voices out of my head. DW.jsteiger said:It is the same circuit that Tubemooley was referring too. He is psycho BTW and probably off his meds, so be careful!Just kidding Dana you Q8 maniac!
Cheers, Jeff
jsteiger said:Did you slug the switch to give you some sort of voltage drop when in the center position? This is possibly being handled in PT or ITB some way. Maybe you don't need this.
jsteiger said:So, 4 Inverting ACA boards and a single 2-ACA-Bo card is 20 discrete opamps. Typically, a 2520 style amp will draw around 22-25mA when idle and around 50-52mA when driving a 600 ohm load. That's per rail. That has been my experience anyways. So worst case you will draw 52mA times 20 DOA's is 1040mA or just over 1A. I would gather any supply that will give you 1.2-1.5A will be fine. Actually, the DOA's on the Inverting ACA cards will never draw that much as they have a very small load. You may not find a dedicated 2 rail, bipolar PSU project around. There may be one but I don't recall seeing it. Not to pimp but you could always get a 51x PSU PCB and only build out 2 of the rails. Leave the rest of it unpopulated. Maybe someday in the future you could build out the other main bipolar rails for +/-16V or whatever. Same with the 48V section. Just don't build it. Just a thought.
Johndcx said:Hey Brian
are you using trsfos on inputs,or line cards?
