klem
Can't seem to find this, what is the mA available per slot, and does it change if using SMPS vs. floor PSU?
The SMPS is 2A per rail divided by 11 so 181mA per slot of course some headroom needs to be factored in. The toroidal transformer is rated at 2.2A with no load. We always figured it would safely provide the 130mA per slot VPR spec with some headroom.Can't seem to find this, what is the mA available per slot, and does it change if using SMPS vs. floor PSU?
Maximum worst case should always be less than 75mAwhile on subject, do you have a rough approximation of what a VP28 would draw at ~50% of full gain in mic mode?
While you're hear, when can I get a complete kit for your comp module. I've been in need of 8 of them for like 3 years nowMaximum worst case should always be less than 75mA
