[BUILD] CAPI 511-VPR~Filtered 500 Series 11 Space Rack~Official Support Thread
Can't seem to find this, what is the mA available per slot, and does it change if using SMPS vs. floor PSU?
The SMPS is 2A per rail divided by 11 so 181mA per slot of course some headroom needs to be factored in. The toroidal transformer is rated at 2.2A with no load. We always figured it would safely provide the 130mA per slot VPR spec with some headroom.
while on subject, do you have a rough approximation of what a VP28 would draw at ~50% of full gain in mic mode?
Hi Jeff,
hypothetically speaking, if an inexperienced builder installed the filter caps in reverse and they blew up, what would the correct part numbers be to replace them? Would you be able to share those? We do know the capacitor specs, but are unsure of the physical dimensions and lead spacing.
Hi Jeff,
Jeff is on vacation until the 22nd. Probably not checking the boards right now. I'm anxiously waiting for him to get back with DB25 lunchboxes and compressors
I have a quick question for you guys before I get home from work and dive into troubleshooting this thing. I’m having issues with channel 8 passing signal through a Reddish EQ. The EQ works in other channels, and I tested a sound Skulptor comp which passed signal just fine. Anyone have any idea where I might start?
Are you 100% sure its the rack and not an outside cable or patchbay issue?
Yeah, I tried two of the same eqs, and neither would pass signal, unless they were bypassed. Tried a compressor in the slot, and it worked perfectly. Wouldn’t that rule out a cable? I thought that maybe the Eq wasn’t sitting far enough in the slot, so I tried an extender card, but it gave the same results.
I would use a DMM to beep from the input side of the DB25 to the rack slot's input and the same for the output. I'd assume you have a short or couple bad solder joints on one or both of the flex PCBs.
You nailed it! It was a cold solder joint on the output ribbon. Thanks Jeff! 🍻
