OK.
I would start by taking some measurements from the properly working module. After injecting a signal, take a measurement of your choice at the output of each amplifier stage then see where the gain increases in the hot module.
1st reading: negative side of C2 on the Main PCB.
2nd reading: output pin of A1, DF on CB PCB
3rd reading: output pin of A2, DF on CB PCB
4th reading: output pin of A4, DTO5 on CB PCB
5th reading: output pin of A3, DTO5 on CB PCB
6th reading: neg side of C12 on the Main PCB
Those are in signal flow order.
We'll figure out the problem stage and go from there.
