@trumanaudio, are the opamps you are using tested in something else so you are 100% sure they are solid? That is always the very first thing to rule out.
There is likely some other issue then. Maybe something is wrong with your testing setup. Do these modules pass audio close to unity gain? I would reset the RV2 trimmers to half way. Do this by turning them repeatedly one way until you here a slight click coming from the trimmer acoustically. Then count 12.5 revolutions back the opposite way. This should be close to mid value. IIRC throughput signal will be .5dB or so low. If yours its drastically off from that then there are bigger issues at play here.trumanaudio said:I haven't tested them in something else. I am getting pre-built opamps tomorrow that I will try.
Just seems strange because both units Im working on are functioning in the same way, same issues, and with 4 different op-amp kits.
Sorry I must have missed the email. Things get hectic around here. I have not had a built unit here in ages but don't think they were much over 75mA per rail per unit.Blackdawg said:I emailed Jeff to ask this but its been a week with no reply.
Does anyone who has some of these know what the current draw is? Trying to build a mixer with TAC racks and hoping to power 3 with one PSU.
Monte
jsteiger said:Sorry I must have missed the email. Things get hectic around here. I have not had a built unit here in ages but don't think they were much over 75mA per rail per unit.
The LED circuit for this build is very simple. I would first think that you have them in backwards.ninopelo29 said:Hello,
I own two ML2 Rev B.3 units and one of them has an issue with the LED's for Bypass and Actuate: neither will light in either position of the respective switch.
I pulled the unit and PR4 is completely burned. It still reads 9 ohms in-circuit (PR3 is reading as 10.1 ohms), but it is clearly damaged.
I can replace the resistor, but I imagine there is another issue that is causing the current to be too high through that resistor.
Would you be able to provide a bit of direction of what could be wrong? I am able to read schematics and repair the unit if you see fit to send me one.
Thanks for your help.
PR4 is the power damping R for A3, the receiver opamp. You have a build error on that opamp or it is not seated fully.
jsteiger said:Hi Monte
I would first rule out opamps, if they were built from kits.
OK since you have a good module, inject a sine wave and measure AC voltage at the Test Points. Notate all of you readings on the good one. Then do the same on the bad one and report back where things go bad.Blackdawg said:Hi Jeff,
Definitely not the op amps. I'm using two Rogue5s from LTLO. In fact to make sure I used the same two in the first unit that calibrated just fine.
Monte
jsteiger said:OK since you have a good module, inject a sine wave and measure AC voltage at the Test Points. Notate all of you readings on the good one. Then do the same on the bad one and report back where things go bad.
The only things between TP3 and TP4 are the output transformer T1, the stepped fader and the trim switch. I would make sure that the fader is set to 0 and then first probe at the T (top) of the fader connection.Blackdawg said:
Hi Jeff,
Here are my measurements.
Unit 1 Unit 2
TP +1 1.718 1.716
TP -1 1.728 1.729
TP 2 1.708 1.706
TP 3 3.043 3.042
TP 4 0.75 0.04
TP 5 0.748 0.04
TP 6 0.744 0.04
TP 7 0.742 0.04
TP 8 0.742 0.04
TP 9 1.775 0.078
Something g definitely off from TP4 onwards
jsteiger said:The only things between TP3 and TP4 are the output transformer T1, the stepped fader and the trim switch. I would make sure that the fader is set to 0 and then first probe at the T (top) of the fader connection.
