Opamps and/or the discrete followers.I have built six of these. Four work great, but two have low/sputtery output. Is there a good spot I should start looking at?
Backwards red LED or backwards diode right near those 2 LEDs.Thank you so much. All are healthy now except one. The green active LED is always on. The red bypass doesn't light, even when in that mode. The audio definitely does. Is this bad relay? Or a component to check in between that path? Thanks so much for the assistance!
Thanks Jeff. The Red LED was reversed. Fixed now - thanks so much!Backwards red LED or backwards diode right near those 2 LEDs.
Agreed. I found the ST2 instructions which add some more detail but there isn’t a description of which test point to use for the Rev B.3. The old instructions suggest the output of C3?Hey all! I have 2 of these sitting on the bench, appearing to work perfectly. The manual for the CMRR calibration seems to be rather outdated. Is there a new method, or simpler method maybe, for the current revision of boards? I'm eager to hear these!
I’m using the extension jig.
Yep! After much hurumphing, found these very same docs!Yes, I also highly recommend the extension jig with the CMRR switch. Otherwise build your own "calibration cable" like chunger (see post #65). With the jig you can ignore the other connections in the support docs (they are for this special cable) and just make your normal audio connections (instructions are written on the jig PCB).
You'll find in the support doc's, at the very end of the VC528 ML2 assembly aid Rev_1 [Last upload 9/19/2015]:
**Final Adjustments**
3. For the CMRR adjustment of RV1, refer to the directions on the Extension Jig. Your output
monitoring connections should be made as shown in the following pic.
It's the same connections on Rev B.3 (negative side of C7 and GND) for output monitoring (VAC with DMM).
Also, search on the support docs page for "CMRR". You'll find this pdf:
VC528 CMRR Adjustment. Follow these instructions (along with the ext. jig if you have one) for the trimmer adjustment.
Cheers!
