GrievousAngel
Active member
Any idea why I am seeing ~ 4VDC at the ML2 output? This seems like an usual failure point ... has anyone seen this before?
This happens only if ML2 is active and A3 or A4 is installed.
First thought was something related to K2 (relay that by-passes A4/T2 ouput. Looking in this area now. Appear OK so far. I checked all diodes for proper junction voltage drop, all OK.
I am also looking at the DF.1 (A1 and A2).
Not likely a bad 2520 right? I see the DC when either A3 or A4 is plugged in.
CMR adjustments would have no bearing on this correct?
Since this is a coupling capacitor design, I would think a electro capacitor related issue, but test OK so far.
TP V+ / TPV- read as expected, ie. ~ Input voltage.
Suggestions?
Thanks.
Suggestions?
Thanks.
