kante1603
Good to hear!Paxkal said:Actually the solder joints ....
Thank you all !!!!
So all are up and running?
Best regards,
Udo.
Thank you all !!!!
This sounds exactly like the last guys problem. Bad solder joint somewhere. Things changing here and there typically points to a bad solder joint. Can't really tell you where though but I would look at the resistor network behind the gain switch as well as the 200Ω R's and the 330µF cap.frenkonio said:Hi guys, got a issue with a VP28 that was made several months ago. Today the gain seems fixed. I mean, there's no change in gain using the Grayhill stepped pot. Gain is fixed. I tried to swap opamps but the issue is still there. Pad works, HPF works, signal led is ok, Mic/Line switch works. Then, after a couple of hours, I decided to put a line signal and press MIC button. After this crazy volume rising the knob came back to work. What may have caused this?
jsteiger said:This sounds exactly like the last guys problem. Bad solder joint somewhere. Things changing here and there typically points to a bad solder joint. Can't really tell you where though but I would look at the resistor network behind the gain switch as well as the 200Ω R's and the 330µF cap.
Yeah its OK temporarily but needs to be 59k. It will change the load on the input slightly and lower the operating level. Its very slight but you'll want it to match for any stereo use etc. Send me an email thru the store and I'll mail you one.pkordel said:Quick question: Somehow R7 went missing, a 59K MF. I do have an equivalent, a 56K3 MF. OK to sub?
pkordel said:I have an issue with the output fader grayhill switch. At the zero setting, there appears to be no attenuation and then one click to the right I end up where I'm guessing the lowest gain setting should be, then it slowly climbs to where I assume unity gain should be. I checked the resistors against the BOM and a working VP28 I have and they appear correct, also reflowed the RF resistors. It almost seems like the grayhill stops are off, have you ever experienced that? I have no previous experience with those switches, they are the variety where the stops are already set. Once the almighty desoldering tool arrives I'll redo that whole part of the PCB, just curious to hear if there have been any faulty grayhills around this thread.
I would love to know how I could troubleshoot a grayhill output fader issue with a DMM. Any pointers?
Potato Cakes said:Have yet to encounter a faulty gray hill switch of any kind, but that doesn't mean it is impossible. To test turn the switch all the way CW or CCW, doesn't matter which. One probe of DMM on the pole (the connection by itself) and the other on one end of the row of pins, depending on your switch position. Once you find that out, turn the switch one click and you should have continuity on the next pin in on the row of pins and the pole. Rinse and repeat. You should not have continuity between any of the pins in the row of pins on a Grayhill switch (at least in this design).
And just to clarify, when you say the "zero setting," do you mean in the middle (0=unity gain=no attenuation) or do you mean fully CCW?
Paul
jsteiger said:As history has it, your issues are likely not the Grayhill switch. Can you post a pic of the bottom side of the board where the fader switch and resistors are?
pkordel said:Sure Jeff, here is the bottom.
Potato Cakes said:Can you do a test of all the switch positions? It may just be the factory stop is in the wrong the place. The switch itself may be fine. You can actually fix that yourself if you want to as I have had to open up several of the continuous rotation versions and install my own stop pins.
Paul
pkordel said:Sure Paul, I suspect the factory stops as well...
Yes indeed, it was the factory stops. Now to open up the switch.
pkordel said:Well, opening it was fairly easy, not sure if I'll be able to re-assemble it haha! Gotta work now, glad I had a spare switch to get back up and running.
