Could it be an outside the module issue? Have you tried a different rack slot, cabling, mic etc?
For kicks, just try removing the 120µF cap ands see if that does it. If so I can send you a replacement.ninopelo29 said:The sound happens without a mic or mic cable connected. The only cable I have connected is the output 1/4" which makes no noise when connected to the second module.
I've tried every slot in my Radial Workhorse and the good module makes no noise in any slot and the bad one makes noise in every slot.
The noise only happens when the phantom power is on. When I initially powered the cards up, there was no noise, tho. It started making a slight crackle after about 10 minutes and then got full blown crazy after 15 minutes and hasn't stopped since. It makes me feel like a part went bad...I'm gonna replace the phantom components and eliminate that as a possibility.
Can I order the components in the phantom power circuit from you?
...and thanks again for all your help Jeff! You rock, sir!
I myself have never heard of such a thing. Are you sure it was on the gain pot? I'm not imagining a way this could happen.jeroberts said:Hi All,
I am working on my first VP-26 build. I finished my build and plugged the unit into my 500 series rack. Everything was working perfectly for a few minutes, then there was a pop and the VP-26 started producing smoke. Now it isn't working at all. After a quick inspection, it looks like the one of the connections on the gain knob is the thing that blew. Has anyone had this happen to them? If so, what can I do to fix it?
Josh
jsteiger said:It was most likely the opamp.
If you smoked something it should be kinda easy to spot. My age old rule of thumb, never start with a fresh preamp kit and a fresh opamp build. Too many variables to trouble shoot. You need to have one or the other in known to be good working condition. If its the opamp, its best to post in the respective opamp build thread.jeroberts said:jsteiger said:It was most likely the opamp.
Ok. How could I check to make sure it's the opamp? Also, would that entail getting a new opamp or do you think I could fix it?
