Potato Cakes
How hot are your regulators getting? Are you using big enough heat sinks?
Paul
Paul
fripholm said:I've put the additional footprints for 3055 and 2955 on the board to have options, but have never actually tried it with those nor do I know of anyone who has (ANYONE??). They're pretty similar though and theoretically should work but it's worth a try and change these to BD139/140 - if you happen to have them at hand. Or maybe one of them is faulty...
brewbacca said:Silly question: how do I measure the current draw of the circuit?
brewbacca said:That makes sense, thanks!
So with R75 the DC current on the +positive rail is around 0.04 amps (although it starts around 0.07 amps and then drops quickly).
Without R75 the DC current is around 0.02 amps.
In both cases the negative rail is around 0.03 amps.
brewbacca said:So with R75 the DC current on the +positive rail is around 0.04 amps (although it starts around 0.07 amps and then drops quickly).
I'm getting around 60vac from the transformer.
