scott2000
.....bridge rectifier have ac after it????
What's the reading at R3 after it??
JCN1218 said:I'm reading 48VDC as well as 18VAC on R3 right after the rectifier
Ilya said:If you disconnect the boards from PSU do you still see AC at the PSU output (when unloaded)? If yes, that's where your problem is.
Otherwise it may be an oscillation. But it must be very huge. Do you have a scope? Can you see what that AC looks like?
Fripholm is right,you‘ll most likely end with a messed up unit and totally disappointed.fripholm said:James, I think you have too many variables to deal with when doing the third step before the first and wire up the relays before even getting the basic functionality of the unit right. Do this when everything else is working!
kante1603 said:Fripholm is right,you‘ll most likely end with a messed up unit and totally disappointed.
That is not a propper way to sort out possible issues.The key is patience and logical thinking.
Please always read carefully and follow his recommendations.Take a deep breath and start again.
Best regards,
Udo.
ron_swanson said:Hi all!
Slowly working to assemble the parts to start this build.
Sorry if this was covered earlier in this thread, I must have missed it if so... wondering what the minimum enclosure depth I should consider when using fripholm's PCB's and PSU PCB in a stereo configuration? The PCB's are rather small, so I'm wondering if I can get away with an enclosure smaller than 14" in depth without running into access and / or power supply or wire routing noise issues?
Thanks in advance!
Greg
Rob Flinn said:You could easily use a 14" depth rack case with room to spare.
