With too much time to spare (unfortunately!), I came back to finally tackle my TTx and find out what is wrong with my build!
I bought different zeners (1N5231) long time ago but had no time to swap them. Now I finally did that.
It solved all of my noises and nasty looking waveforms. Just like that. It's all good and I calibrated it without problem.
My final problem was that I did my own front panel that included both auto-release and hold controls. So I wrapped my head to try to find a solution how to make both possible. Even though Fripholm stated in his manual that it's not possible to have both, I managed to do so.
First I had to find how to wire it differently from the diagram that is in the build manual. That was rather easy. I didn't connect the wiper of the hold pot to the lower leg of R51, but instead I connected it to the pole of the A-R switch. The same pole that has to be disconnected from the ground. Wiper gets connected to that pole and it also has to be connected to the anode of the diode that is in parallel with the release pot and R51. This is basically the same as it's in build manual but it keeps the switch on the release pot active.
I had working Hold potentiometer but now it acted very weird. As soon as I moved from CCW position it would slam the GR meter all the way. I found out that it worked for few degrees of rotation but after that it was putting out simply too much voltage above the ground and that kicked massive amount of GR. Voltage from bottom leg of R58 was feeding CW with around 14Vdc if I remember correctly. And useful hold was up to 1.3Vdc coming out of the wiper. That was the voltage that maxed the gain reduction. So I tried to lower it down. I replaced R58 with 160K (!!) and left the lower leg of it in the air to be able to connect the CW directly to it. That worked! Now I had useful range of the Hold potentiometer. I kept the original 10K linear pot. I was curious if going from 6K2 to 160K changed the behavior of the compression so I took it off to compare. To my ears, compression was the same with Hold completely removed and R58 back to 6K2. So I decided to keep it with R58 at 160K and hold connected my way.
I have attached the schematic of how I connected it to this post. It's easier to draw it than to describe.
Now I'm a happy owner of another succesful build!
Btw, this compressor is amazing! Very different character from all the other compressors I've built so far (176, 160vu, 1176, LA4, Federal, Pico, GSSL...). I'll post some samples in few days.
Luka
