Mike Havok
Active member
- Joined
- Feb 26, 2017
- Messages
- 43
Quick question:
SC and Mode switches, MBB or BBM?
fripholm said:It's been a while but if I remember correctly, I was trying to lower the distortion and/or noise a bit by lowering the threshold so the compression kicks in a little earlier. This increased the gain in the sidechain and with it the compression ratio. In this design a higher ratio also comes with a much harder compression knee hence D13 was added and the following resistor had to be changed to compensate for the higher gain. Despite those changes, I wanted the comp/lim knee to be like the original.
In the end, the threshold is only slightly lower than the original but the overall character should be the same. One could argue that it wasn't even worth it :
For other changes see the build guide and this thread. It's all been discussed before. AFAIK Fester's version is true to the original EMI schematic - I don't know anything about Chandler's version...
Chad said:Just thought I'd show my finished build![]()
Thanks fripholm for the project, the guide was very comprehensive.
I ended up making my own knobs and silkscreening a frontpanel, 3D printed Sifam style coverings for the cheap eBay VU meters.
Putting the power supply in a remote box cured my hum woes, as well as keeping the audio transformers away from each other.
Hit me up if you're interested in knobs for this project![]()
andow said:Does anybody have two of these sidechain filter boards left?
fripholm said:Write a PM to member ToBSn. Last time I heard he still had these left.
andow said:I did, but never got a reply... :-\
ToBSn said:Hi andow,
no pm received here. I have to check if there are some left.
