thomb
Member
Thank you Fripholm.
JMan said:Hey all, I’m slowly but surely getting my boards stuffed, and now thinking about the next steps. I’ve read through Fripholm’s fabulous build guide numerous times, and I have to say I really appreciate how thorough it is!
I’m looking at transformers for my next purchase, and I’m hoping to get some thoughts from you all, as this is actually my first build that uses audio transformers and I’m feeling that newbie uncertainty. I’m currently thinking about the Carnhill 9046 wired for 2:1 on input, and Sowter 1460 600:600 on output (links below. I found both of these mentioned much earlier in the thread).
Very curious to hear your thoughts on these, or if you have better suggestions — I’ve seen that people have used other xfmrs throughout this thread, and I’m open to guidance!
Carnhill: http://www.audiomaintenance.com/acatalog/CA%2d18%2dVTB9046M%5fextended%5finfo%2ehtml
Sowter: https://www.sowter.co.uk/cgi-bin/ss000001.pl?page=search&SS=1460&PR=-1&TB=O&ACTION=Go%21
Potato Cakes said:I put Sowters in mine. A bit more expensive and there was a several week lead time although Don Audio sometimes has various Sowter transformers in stock. Carnhills are more readily available and less expensive. Both will sound great.
Paul
JMan said:Hey Paul,
Thanks for your input!
Do you recall which models of Sowters you used? (I know it's gotta be here in the thread somewhere, I just haven't been able to go back and find it).
Since this is my first time using audio transformers, I'm hoping that whatever I end up choosing will be pretty straightforward to implement, as I want to save any more complicated adjustments and alterations for future projects when I have a little experience.
ToBSn said:Sounds like a grounding issue.
If I remember correctly I had a similar problem when I had the boards running on my desk without a case.
fripholm said:Have you tried the recommended (fixed) value of 12k for R22 and replaced trimmer FT2A with a jumper? There's a lot of interaction between what the trimmers for R22 and R56 do and the window is pretty small where the circuit behaves correctly.
Are there any other mods like the hold circuit at this point? What's the test signal level going into the board? It has to be pretty low for it not to distort - usually the 2:1 input transformer takes care of this.
dunk91 said:I'm using an 1Vpp sine, it should be fine also without a 2:1 on input, right?
May I ask you I you know a valid reason for comp mode to not work when limit seems fine? (beside bad wiring, wich I should have excluded hardwiring various mode)
fripholm said:1Vpp input signal is pretty high if hard wired and not further attenuated by the input control but COMP mode should still work.
No idea, sorry. Have you tried to lower R56 below 1k. When I had the finished boards from another forum member on the bench here for troubleshooting, it turned out that it had to be 820 ohms on both. He also had some strange issues that we were able to fix by this change.
JMan said:Hey all,
I'm still waffling back and forth on what transformers to go with. In the meantime, I'm picking up some rotary switches (Elma Type 04) for the Input/Output controls from Don Audio. I want to make sure I've got the right thing -- 1 Wafer 1x24 Shorting 15˙
Does this look right? I'm fairly confident, but since this project is presenting me with a lot of firsts and these switches are pricey, I have no shame about triple-ultra-checking.
JMan said:Hey all,
JMan said:Thanks for your input, guys!
Are these the uraltone ones (I couldn't find any branded as such)? In which case, I'd just ignore the second wafer, right?
https://www.don-audio.com/Rotary-Switch-2024-2-Pole-24-Position
tomas1808 said:Is there a trace layout file available to DIY a TG1 board?
