Murdock said:When we take the "normal" 600 Ohm input, the secondary Impedance is 150 ohms. Isn't that to low?
fripholm said:You are right in that a transformer with a 2:1 winding ratio has a 4:1 impedance ratio. But in the case of an input transformer, the load that is connected across its secondary is 'reflected' with that ratio to the primary winding. It means that the input stage of the compressor with its input impedance of about 3 kOhms is 4 times that seen from the outside world through the transformer - about 12kOhms - which is in the ballpark of any line input.
'600 ohms' is just a meaningless rating for what a transformer is designed to work with - in this case, 'if it had a 150 ohms load across the secondary, the primary would see 600 ohms'.
fripholm said:Absolutely! I meant 'meaningless' in the sense that the transformer can be used only at this particular impedance.
Murdock said:So it's safe to say, that a 600:150 Ohm transformer is not suitable for this circuit, right? 10k:2k5 would be better.
fripholm said:The datasheet only mentions wiring options for 4:1 and 1:1 ratios but if you wire both the primary and secondary in parallel or both in series you should be getting 2:1 as well.
fripholm said:The meters will not show anything useful before there is some clean audio passing from input to output. Did you do any of the audio calibration steps (not the meters)?
Please check one board at a time, block by block, step by step. Carefully read (and follow) the guide and this thread. For example, see this post on how to inject a test signal directly to the output stage to confirm that it's working correctly. Or check your voltages against the chart from this post.
BerndVP said:On the audio pad that you give, is this directly coming from the audio interface or first thru the input transformer ?
octavez said:Would you recommend waiting on the VTB 9046 to be back in stock?
brewbacca said:I don't think I did this correctly :-\
