Hairball Audio said:
mrtomcat said:
I just finished my second Elements Copper Pre Amp...(my 5th Hairball build all together )
I ran into a problem with this one.
After I was done there was no sound at all, so I started checking and the capacitor in C401 was dead. So I ordered a new one from Mouser.
It came today and I replaced it. Now I am getting sound but not even close to the volume of the first copper.
I have to up input and output by 3 steps each more than on the first copper.
Is there anything you can think of to check. This is where my electronics knowledge ends...
Could it be the capacitor in C401? I thought I had the exact one of the kit but the one that came with the kit shows .1 uf and 63v and one that came from mouser says .1 uf 100 volt (mouser part 594-2222-370-22104)
since the BOM didn't specify the voltage I did not pay attention to this...I probably should have.
Could that be the reason or is there anything else you can think off
The unit works and it's not the end of the world but I would really like to get them both as close as possible.
thanks
Thomas
The cap voltage would not cause that.
Low volume could be a lot of things:
-Gain resistor swapped values
-Any improper resistor value or cap value
-Improper transformer wiring
-missing a link
-bad op-amp (switch the op-amp with your other build...does the low gain follow the op-amp?)
We also have a $50 flat rate repair on those.
Mike
I exchanged the op amps, same result. I compared the values visually and with a Meter between the two units and only R501 was different in readings (visually the same). The Resistor on the second copper read 0.22 (20k setting) and the first one 0.33... they are both supposed to be 4.7k as you know. But I know once in the PCB readings can be off. So I took the one from the second copper out and it does read 4.7k, so I put it back in.
Both seem to be otherwise identical. All the Caps return a similar value...again, I know on the PCB it's tough to get correct readings and visually everything looks the same.
transformers are wired correctly as well.
The other strange thing is that the second copper sounds completely different, much brighter than the first...both sound fantastic but not alike.
So I am not sure what to do... I wanted a somewhat matched pair.
So the issues didn't follow the op-amps?
Does the one still have low gain?
Mike
Since part of this whole thing is to learn I am a bit hesitant to ship it in... but might end up doing so.
Any further ideas?
