Echo North
ratty_7 said:Ok.... With the Ratio at 20:1 and the meter at +4 and the input at around 11 o'clock and the out put at 9 o'clock attack off/on I get a drop of -10dB from 0db on the meter. After re-calibrating steps 1 & 2 on both units, when I turn the attack on and the meter from +4 to GR, I am now getting a drop of almost -10db. In the pic below the inputs and outputs ended up on both units and they were exactly the same, except the meter is a little out ....?
In +4? Keep it in GR mode always.
http://www.hairballaudio.com/blog/resources/build-guides/fetrack-v2-buildbrstep-4-calibration
not sure what your calibration procedure is...nothing I've used.
