Jacob123588
Member
- Joined
- Dec 17, 2016
- Messages
- 15
Hairball Audio said:You said it doesn't turn on but you were able to test the voltages accurately? That would not be possible.
Confirm your fuse is in and not blown, confirm your voltage select switch is set correctly, confirm your DMM is set to AC V.
Mike
I tested the power supply. It was all good, so I continued pressing on. I had finished assembly and I was getting ready to calibrate, when I pressed from off to GR, no lights no needle movement, nothing so I plugged in some signal still nothing. So I figured I'd test the power supply again, and the ground reads good, 0.2. 30v reads 0 and -10v also reads 0.
