landispearce
Member
- Joined
- Apr 12, 2017
- Messages
- 7
Hairball Audio said:You've got some disconnect between your TP15 and TP22. Have a look at the schematic:
http://mnats.net/files/fetrack/fet_rack_d_doc_v1.11.pdf
This is the D but this part is the same for the A other than a few resistor values. Or you can go to MNATS.NET and download the A if that's what you're working on.
Find TP15...it's right before the output pot along the top in the middle. Look how the AC travels down through the relay then to the ratio PCB, exists the ratio PCB at the bottom depending on what switch is enabled then through the attack switch to PAD 22.
See if you can trace that AC to pad 22...it's dying somewhere along that short linear path.
Probably a bad joint or lifted pad somewhere.
Mike
Mike, So i was able to find the issue, it was in the ratio board. I was able to complete the calibration without problem. Thank you for your help!
Also, seems to be quite distorted when i test with actual audio. I understand that blue stripes are indeed distorted more so but it seems like there is something wrong. First blue stripe I've built so I could just be wrong.
