Hi everyone,
I've sent a mail to hairball but I thought I'd write here as well as Mike answers in this thread as well.
I've built two Rev D . nothing to report regarding the built, well documented, really top notch.
Seems my device is not even passing audio
On both of my FETs when calibrating Qbias, I get no AC reading on the output between OUT + and OUT -.
Also I understand that when the device is on OFF,, it should be in pass trough. Is that right? Because I also get no AC reading on the output between OUT + and OUT -. in OFF
I do get a reading on the output between OUT + and OUT - but only when i turn up and down the output control then it briefly reads between 0 VAC to 1.5 VAC or so but drops right ways to 0 VAC
To this question:
Set your unit to:
Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR OFF
Release: Full CW
Ratio: 20:1
Meter: GR
Signal: Sine 1kHz @ 0dBu 0.775 VAC
With your DMM measure your AC at the following test points using the chassis as you reference (black probe).
-Input XLR + = FET1: 0.387 VAC / FET2 0.383 VAC
-TP1 = FET1: 0.110 VAC/ FET2 0.139 VAC
-TP15 = FET 1 0VAC / FET2 0VAC
-TP17 = FET 1 0VAC / FET2 0VAC
-Output Transformer BRN = Where is it?
-Output XLR + = FET 1 0VAC / FET2 0VAC
The issue is consistent on both device, I need some heads up
