Echo North
jgremlin said:-Input XLR + .430 VAC
-TP1 .123
-TP15 2.46
-TP17 .382
-Output Transformer BRN 7.13
-Output XLR + 5.44
Looks good. Can you calibrate now?
-TP1 .123
-TP15 2.46
-TP17 .382
-Output XLR + 5.44
Negative. Same as before. I can set Q bias ok. I set meter circuit null adjust and that seems to fine up until I move the shunt back to the normal pins. At that point, the meter goes from 0dB to -20dB and R71 runs out of travel long before the meter hits 0dB.Hairball Audio said:Looks good. Can you calibrate now?
jgremlin said:Negative. Same as before. I can set Q bias ok. I set meter circuit null adjust and that seems to fine up until I move the shunt back to the normal pins. At that point, the meter goes from 0dB to -20dB and R71 runs out of travel long before the meter hits 0dB.
TDJ said:Hello, all!
I've e-mailed hairball about my issue, but I thought I would get everyone elses input in the meantime. I just finished my 3rd blue stripe. When I went to begin the calibration process, i set up my signal generator - then noticed that my output knob had little to no effect on the output volume. I measured my output and was getting very low readings (around .4VAC with the knob cranked, i believe). So, I took the bottom off and measured resistance between the middle lug and a side. My reading would jump around and never got above 40-50k'ish. I realize that you can't get an accurate measurement in the circuit, so I decided to take the pot out to test it. When I was removing it, one of the lugs on the pot came right out. I don't know whether this was my problem to begin with, or if I got it too hot when removing it. So, in the meantime, until I get another one, do you guys have any suggestions of other things to check? I've given everything a good look over, and can't seem to find anything installed wrong. I've even checked to make sure i didn't mix up any 470, 4.7k, or 470k's etc. Thanks in advance!
jgremlin said:I went through the gain meter driver amp section and the gr control amp section. All the values are correct and all the joints look good to me. But I can't get the calibrations done and near I can tell, the reason is because its not compressing.
With meter in +4 mode I can feed a test tone and raise the input knob pretty hot then bring up the output knob enough to get the meter around zero. If I then turn the attack knob from off to full cw, the meter doesn't move. In addition, level of the signal going back to my DAW doesn't change. Tried all the ratios, same result. No drop in level when you go from off to full CW on the attack knob.
She ain't compressing and I'm kind of out of ideas. I've checked everything on the boards multiple times. It all looks right. Might be time to box it up and let you guys have a crack at it.
jgremlin said:TP22
20:1 - .003 VAC
12:1 - .002
8:1 - .002
4:1 - .002
TP21
20:1 - -6.8 VAC
12:1 - -3.89
8:1 - -2.8
4:1 - -1.896
CR2
20:1 - .001 VDC
12:1 - .000
8:1 - .000
4:1 - .000
Yes. Full CWHairball Audio said:That's with GR on?
jgremlin said:Yes. Full CW
jgremlin said:TP15 GR on: 1.783 VAC
TP15 GR off: 1.783 VAC
Not sure if normal but volts will move a bit if I gently tap the output control post.
1.785 side toward the connectorHairball Audio said:1. You have a rev D right?
2. With GR ON, what if you AC V at either side of R78 (Ratio PCB)?
Mike
jgremlin said:1.785 side toward the connector
1.420 toward edge of board
That's GR on with the test tone going.
Affirmative.Hairball Audio said:In 20:1?
But nothing at pad 22?
jgremlin said:Affirmative.
jgremlin said:Ok I'll dig into it. I've already reflowed the connector on the main board but I'll pull the ratio PCB and go over everything. Thanks for the help Mike.
