alex_dempsey
Active member
- Joined
- Mar 2, 2018
- Messages
- 32
Hairball Audio said:What about the output between + and - ?
Mike
Im reading about 8.4VAC between the + and - on the output XLR.
Mike
alex_dempsey said:Im reading about 8.4VAC between the + and - on the output XLR.
Hairball Audio said:All sounds great.
Try setting your QBias again. Any luck?
alex_dempsey said:Nope. The Q-Bias adjustment still has no effect on the voltage reading across the output test points.
Hairball Audio said:What is you DC V at the gate of Q1 from one end of the QBias trimmer to the other?
Mike
alex_dempsey said:AHHHHH!! I never put in Q1!!!! I bet that will solve all my problems!!
scott2000 said:Where might I find one of these Q1s?
LOL
alex_dempsey said:Well it worked!! Thanks so much for the help. I have everything calibrated and didn't run into any other big issues.
The only issue I have now is that the gain nobs are very very sensitive that I think is definitely unnatural. Any ideas of adjustments or places to check? Sounds like I might have a wrong resistor someone but not sure where it might be. Any ideas?
Hairball Audio said:We've talked about the Rev A being really hot on the last page or two. You can turn down your clip gain, or I posted a 4 resistor mod to fix it.
Mike
alex_dempsey said:Thanks Mike!
Is the mod just in the forum or is it posted somewhere on the site?
Alex
cdeboda said:I swapped out those four ac section resistors on the ratio board with 10x the values. Found it to be impossible to get any reasonable amount of gain reduction and very difficult to calibrate. So I swapped them out again with 5x the original values (two resistors each and a bit of creativity to get the values) and it feels MUCH better. No more carefully blowing on the pot at 7o’clock to dial in some GR.
Still having a bit of trouble calibrating the tracking adjust, however. It’s just short of showing -10dB at the end of the trimmers rotation. I’ve ordered a 2.5k trimmer to swap in - hopefully that’ll do it. This of course was much further off with the 10x resistors. Any insight on this?
Measured the compression curves as well - pictures to follow. Found it interesting that the ratio selection (at least on my unit) doesn’t actually change the threshold like in the classic 1176 compression curves we’ve all seen. Any idea why?
cdeboda said:All four ratios begin compression at about the same threshold, unlike the compression curves I’ve seen and heard in these units. Not an issue, just struck me as odd.
Hairball Audio said:https://groupdiy.com/index.php?topic=63600.msg870974#msg870974
I would suggest 10x.
So 47K would become 470K.
alex_dempsey said:Hi Mike,
So I'm actually having a different problem than mentioned before. Its not really that the input is too hot its a little different. On GR mode, the meter is pinned to 0 anytime I go above like 48 on the input gain. On the +4 setting, with the output nob at unity, the input nob needs to be cranked to almost 0 for the meter to get back to unity. And its not a smooth increase in gain it spikes and jumps a bit. I'm not totally sure I did the final step of calibration correct but this doesn't just sound like a calibration issue to me. Any ideas of where to start looking?
I referenced a working black face 1176 to make sure I wasn't crazy lol.
- Alex
Hairball Audio said:Not enough info. No idea what your input level is or if GR is enabled. If GR enabled you'd have to crank your input that high. Eventually the input gain levels off between increasing signal and gain.
The beginning, of the turn on the input pad will spike. It's not a volume pot, it's a 35ish dB variable pad. So it has an on/off point, it's a little different than the originals which used a very unique and hard to replicate input pad, at least that early turn smoothness. However, it happens only at the start around 48, some place you normally wouldn't be, especially with that mod in place or on a stock D/F.
Mike
alex_dempsey said:With the meter set to GR, I have to drop my input nob all the way down to 48ish (7 o'clock) to keep the meter from being pinned at zero.
