Echo North
nu-tra said:Can I purchase the bourns and will it work with this board? Which model? Thanks
Shoot us an email.
alex_dempsey said:Hello,
I am having some trouble with the power supply on my kit. I just finished building it and the ground test is reading correctly but I'm only reading like 200 mVDC when I do the next test. I've tried looking around for issues but can't seem to find any. Ideas on why I'm not getting any voltage?
Thanks.
seanweaverguitar said:So I'm using the Hairball Rev. A daily now and it's ridiculously good (I've only used it on bass and electric guitars in the middle of my guitar blues-rock project for some instructional work so granted I haven't run acoustic guitar or vocals through it yet but for what I'm doing I can't imagine anything better; I drove the input stage yesterday (GR off) coming out of Lola on a 1x12" open back turned up to 8 and got the most vicious Page kind of dirty guitar-rock rhythm sound) & dreaming about building several more.....
I'm torn between a Rev D and the new Rev F although in time I'm sure I'll wind up with all of them. Stupid question but I'm thinking ahead....
For the Stereo Link on the Rev A, I'm assuming it wouldn't really be right to link that to a different revision? I'm micing cabinets now in stereo so often it's probably another Lola & Rev A to keep things even but just wanted to check in here for suggestions before I officially decide which way to go on the next order. I'm finally getting good guitar sounds!!! Thanks Mike
Sean
Uroarz said:Hey guys I'm calibrating my 1176 rev A for the second time. What would be a full reset for the pots? i understand CW for the q-bias but what about the others? I'm on the "Reduction Meter Tracking Adjustment" and my output isn't going above 0.293 VAC. I'm putting in 1db 0.775 VAC on the input but the output is maxing out at 0.293 VAC. I'm assuming i need to reset all the pots but let me know. Thanks! -Austin
CBarx said:I'm having troubles in 3 areas. 1st - GR Control Amp values are incredibly low. They are listed below:
.054v - Ratio 20
.024v - Ratio12
.018v - Ratio 8
.015v - Ratio 4
CBarx said:Second, when I probe the anode side of CR2 for GR Control Amp Output testing, I get a complete audio dropout and a quickly declining voltage reading making it near impossible to get an accurate value.
CBarx said:3rd, I've noticed that the ratio ribbon cable must be positioned in the EXACT right spot in order for audio to pass, and for the GR meter to zero. I've tried re-soldering these connectors, but with no improvement to how the unit acts. I'm starting to wonder if there is a short or break in one of the conductors on the cable itself.
Hairball Audio said:Where is this at? Pad 22? Measuring AC?
That's super weird. Not sure about that one.
Could be. You should be able to continuity test between pins on the connectors to see if there is an issue. Are any of the wires crossed on the connector?
Mike
CBarx said:Yes Pad 22 measuring AC
No wires crossed on the connector cable, and continuity is good on all wires. Continuity is good on all pins on CN3 and CN2. Not sure what's going on there. I may try seeing if hitting some solder points will fix anything there. Everything looks good, but crazier things have happened.
Chrome Heart said:Any reason the power resistor wouldn’t be dropping voltage for the vu lamp? Everything appears to be grounded.
Hairball Audio said:Check your relay soldering, R19-22, and R78 values. Make sure you don't have like a 470K where there should be a 47K.
Also can send out a new cable.
Mike
Hairball Audio said:That's super weird. Not sure about that one.
CBarx said:Going through voltages again, and in addition to getting .05v and below at TP 22, I simply cannot perform GR Control Amp voltage checks because CR2 goes nuts every time I hit it with a probe. My 1k sine goes completely silent, meter slams back down to -20, and voltages will bounce all over the place. I assume I should see if I have a replacement CR2 in my stock? I already had a dead CR9 so perhaps I'm just having a bad batch of diodes on this build? CN2 > CN3 cable is getting worse, I think the pins in the housings are not making proper contact unless I put horizontal pressure on the cable.
Hairball Audio said:Could be a bad diode.
If you're not getting a V drop at the output in GR mode, you still need to sort out why you have no AC at PAD 22.
Trace it out on the schematic follow it from PAD 15 where it should be close to a 2VAC to pad 22 and see where it dies. It just goes through the relay, connector, R78 if in 20:1, the ratio switch, back through the connector, through the attack switch, then to pad 22.
Mike
CBarx said:So at .775v on the XLR input I'm getting 3.8v at TP15 @20:1 ratio. Which is 1.8v higher than mentioned above. That's with input and output at 12 o'clock.
Mike
Hairball Audio said:Does that PAD 15 voltage drop at all when you turn on GR?
