Hello, I recently bought a FET/RACK Rev F. I'm wrapped up with all of the soldering, and I'm on the calibration stage. I'm sending a 1Khz signal out of my DAW into the input of the 1176, and have adjusted for it to read .775 VAC at input + and input -. However, when I check the output +/-, I'm not getting the desired reading. More of something like 0.002-0.003 VAC. I noticed I had put the 2K zero adjust trimmer on the top side instead of the bottom, so I de-soldered it and re-soldered it to the bottom side, hoping that would fix it, but still nothing.
The unit does receive power and will turn on when I engage the GR button, but I can't get that read, and the meter won't move when adjusting the input and output.
One thing I'm not sure about is that I can't really get the desired readings for the cathode (30V DC)and anode (-10V DC). For the cathode, I'm getting something along the lines of 0.004V DC on the cathode, and then nothing too solid on the anode. Surprisingly, however, the unit, as I mentioned before, is receiving power and turns on. Do you have any advice for what the issue might be? Thanks in advance!
