Echo North
SunkenCity said:both connectors cn4 and cn5 are junk after heating them enough to get all the leads free, hot pins just warp the plastic.
By force I mean I snipped the leads I could access and removed solder where I could with wick to get it free to access the pads for the connectors.
CR1 tested fine but I might as well replace it with the one you sent.
Not sure where to go from here. It would be a waste of time to stick the replacement trannys in if the problem is somewhere else. I guess recheck everything in the line amp section
You can always have us repair it. Your connectors will be there in 2 days.
https://www.hairballaudio.com/build-support-services
