Echo North
Deejsirois said:The collector of Q4 is where 62Hz is getting crazy amplified (and everywhere after). I have double checked values around that area and everything checks out. I replaced one by one, Q4, C8, R24, R25, R26, and C10. In the process, I discovered that my output pot's middle pin had continuity with the right pin, so I grabbed a spare I had, which also had the same problem. I had one left and thankfully that one is good. I thought that would be the answer, but nope. DC voltages are good.
You're getting GAIN @ 60Hz or you have a LPF causing everything above it to be attenuated?
