Echo North
You're measuring for AC there.
Hairball Audio said:You're measuring for AC there.
Deejsirois said:Rightlol
20:1 = 4.15 VAC
12:1 =2.06
8:1 =1.37
4:1=0.68
Hairball Audio said:Everything seems good. Super weird.
- One of your release pot legs detach? Happens pretty easily.
- When you turn on GR how does your Q1 Gate voltage change? From x to x?
Logging off for the evening....
Deejsirois said:I will check the pot legs tomorrow. GR at Q1 gate goes from -1.276 to 0.364 when GR turned on...0.511 Fully CW
Thanks Mike!
Hairball Audio said:So under the normal test setup, GR ON. What is your AC and DC on either side of CR2 and CR3?
Deejsirois said:Input: 12 O’Clock
Output: 12 O’Clock
Attack: GR ON (fully CW)
Release: Full CW
Meter: GR
Signal: Sine 1kHz @ 0dBu (0.775 VAC across input + and -)
CR2 CR3
0.699 and 0.0623 VAC 0.71 and 0.0625 VAC
-1.761 and -1.41 VDC --1.763 and -1.41 VDC
Should I replace CR2 and CR3?
ghiatorino said:Hi there, hi Mike
i am experiencing almost the same issue as Deejsirois.
I just finished a rev A build.
Units is calibrated and sounds as good as it should,
but..
when GR is engaged i have loads of distortion. Compression works, but sound is awful. Furthermore it seems that it's not catching transients as it should.
double checked usual stuff and found no build errors.
I have another Rev A. Using 5457 for both.
Looking at the output of the 2 units on a spectrum analyzer reveals that the spectrum is identical, except when engaging GR.
New units exhibits a high level of distortion over all the ratios. GR amount is the same.
Traced down the signal with a scope and i found a difference in the GR amp. The new unit has a clipped AC signal, right before entering CR3/CR4
I replaced all the GR amp transistors (using 2n5088) with no result. DC Voltages are correct. components value too.
I replaced the R46 feedback resistor with a 50k pot and found a place where the same control signal passes undistorted. But only result was almost no compression.
Anybody experienced something like this?
Thanks for your time
Rino
forgotteng said:I managed to put some caps in the wrong place and need to get a replacement but I am struggling to find them in stock in a lower quantity. Is there an exceptable replacement for the FK28C0G1H221J cap?
Hairball Audio said:Is this in 20:1? Make sure you're in 20:1....re-check those DC measurements.
Deejsirois said:My bad. At 20:1
-5.86 and -1.43 for CR2
-5.86 and -1.429 for CR3
Hairball Audio said:Everything seems right. You're using all of your own parts right? I'd triple check the stuff you're using has the same footprints etc.
Specifically transistors which all have different footprints.
We generally don't service non-stock builds but I could probably look at it.
Mike
Deejsirois said:This build is the stock build...from the mouser cart from your website. The only substitutions I have made were Elna 100uf Caps. The transistors are the ones from the mouser cart.
Hairball Audio said:I'm just not seeing any weird voltages. You have your own enclosure right? Those 3 mount LBrackets on the back are part of the grounding scheme and they need to be in there.
I'm stumped.
Deejsirois said:Yep, my own enclosure that works for all the other units except this one lol. I did my best to keep it right on par with yours to avoid headaches. I have even swapped this board into a different enclosure that I knew worked with Rev D and Rev F builds. The only thing I have NOT tried is switching out the release and attack assembly. Maybe I will give that a shot. At least I can eliminate that.
Hairball Audio said:Ya that's key to troubleshooting. Swap out as much stuff to try and isolate the problem area. Just not seeing anything weird. Your Gate voltage swings super positive with compression, but that's a super hard place to measure because it's so high impedance and the meter is in parallel with it.
Other than that we have a repair service, you'd just be sending in the PCBs.
Mike
Deejsirois said:Time to CELEBRATE!!! Sweet Jesus, the REV A is working!!! Woohoo, I am not crazy and nor is Mike! Looks like my attack pot is faulty. All the leads are still connected, but that was the culprit. Man, that was driving me crazy. Thanks, Mike, for getting me on the right path!
