[BUILD] Stereo Mastering Insert Switcher PCB - Official Support Thread
Majestic12
Germany
This will be the official support thread for the stereo insert pcb sold by Wayne Kirkwood from KA Electronics
http://www.ka-electronics.com/kaelectronics/MS_Matrix/MS_Matrix.htm
Description and documentation soon to be added.
Nice, i was searching for something like this .... still no description and documentation info ?
Grtzzz,
Danny.
I just got 2 switcher cards!    and want then in the same box as KA's  stereo widener.      How would you say its is best to power it all?
the switcher card run at +24dc    and draw about 125ma when all active      both around 250ma.      then the stereo board requires
+/-15volts.      how best to cleanly power that bad boy.    HELP PLEASE.
Sal
Hotmouth Records.
ruffrecords said:
Why isn't the guy who sells it supporting it?
It actually is my design that is sold by Wayne from KA electronics. I will write some information about it soon, I totally forgot about it here in the forum.
Everybody who needs help can  also use the forum at the KA electronics website .
Cool. That makes sense.
I'd go out on a limb and say yeah but it would be wayyy overkill.  Have you checked out diy-tubes take on the igor bypass switch?  Majestic actually made a bunch too iirc.  They are single channel but used 'in reverse' could be used as insert switches.
fragletrollet said:
Is there any way of using this as a 2x mono insert switcher with independent switching?
Not in an easy way. The relais for L and R channels are all wired in series and switched together. You would have to cut a lot of traces to make these pcbs work in mono.
