..there is no standard way of measuring compressor timings - this is probably your answer..
Ok, well I think I'm going to try a switchable slow attack mod. Think I'll add two (one for each channel) DPDT (on-on-on) switches to switch in either a 33k or 68k resistor to be in series with the 22k attack pot (probably just cut the middle wire from the header and put it there (so between the side chain rectifier diodes and the attack pot). Switch down (shorting wire mode) will be stock 1176 (RC value ranges from 100 us - 4.9 ms), switch middle position will be slower attack (RC value ranges from 7.4ms - 12.2 ms) and switch top position will be slowest attack (RC value ranges from 15.1 ms - 19.9 ms). I'll report back if that explodes or sounds awesome or whatever.
Sweet!I did a similar thing on my MS76 - swapped the 22k pot for 250k to give way more range. Gives around 9 or 10ms max attack, going by how the original 1176 speeds were calculated. I also used a pot with a switch at the slow end of the pot rotation, which to switch in an additional 500k or so resistor for a "slow" mode of about 30ms for situations where you want the transients left intact. Sounds great!
Yes, sorry Gustav, I was very busy...Not much to follow up on, until you report back/try the suggestions!
Gustav
Im sorry, but it is unclear to me what your problem is, and what you are measuring!?Yes, sorry Gustav, I was very busy...
But finally I found time to measure the voltages and some were quite off.
CH1:
1.5V measured: 4.4V (next to wire going to ratio-board)
1.5V measured:4.2V (left from BC107)
CH2:
1.5V measured: 4.3V (next to wire going to ratio-board)
Let me know where to look for an error.
Gearing up for some overkill here....putting a 10 position rotary switch with 9 22k switchable resistors in series with the 22k pot.
https://www.mouser.com/ProductDetail/706-71B36-01A10N
Hi James, I'm still certain we have the same issue. Apologies for not posting more, I have also been busy with work.
I have made some progress with my unit, and I can now get it operating correctly, although the fix is a bit unusual... I'm hoping you would be up for seeing if you get the same results with your unit.
With my unit in 2:1, the meter is buried to the left, and there is very little output. If I physically touch the top of the BC107 next to the 6-pin connector (I've highlighted it on the attached image) the meter springs back to zero where it should be. I can send drums through, and now the unit is compressing properly at all ratios, provided I keep my finger on the top of that transistor.
I know it seems unwise poking around with your fingers, but this component only has 15V DC on it, it won't cause you any harm.
maybe the 25v caps were sufficient in one iteration of the design?
Thank you!film caps are just fine
Ok, so turns out I actuaIIy have 35V tants in their aIready. I aIso do have a 7912 as opposed to a 7910 on the psu. Is that worth repIacing with a 7910? Power seems to work though, Iights up, passes audio, but does not compress.
No, no reaction/GR, this is what I mean by 'it doesn't compress' as in I do not hear compression.-12 instead of -10 is fine, and also reconformied in the thread a few times.
Your voltages on the transistors are good?
You say it doesnt compress, which is not much to go by.
First off, please let us know if you are getting some sort of reaction/GR wtih compression in, but the meter just isnt showing it.
Gustav
Great, just wanted to make sure you had check the outcoming signal as well, since no meter reaction does not equal no processing.No, no reaction/GR, this is what I mean by 'it doesn't compress' as in I do not hear compression.
Ok, finaIIy have some time for this.
1. Don't know how to measure, I assume the meter one side to the reIevant transistor Ieg and the other to ground, but which Ieg?
2. Yes
3. Yes, reIays Ioud and cIear.
4. Yes.
The meters sink to the bottom when no signaI is present, and the Ieft one stays there even in GR mode, whereas the right one pins fuII whack in GR mode. Maybe that's to do with my previous tech having 'done the caIibration' weirdIy.
Register today and take advantage of membership benefits.
