ruckus328
Hey guys, I've been a reader of this forum for a little while now, I just want to say in advance a big "Thank You" for all the great info I've picked up here. I finally have the time to build my first GSSL, but I'm confused on a few things and was hoping one of you might be able to point me in the right direction. I have a fair electronics understanding and I layout PCB's for a living, so I don't forsee me having any problems with this project, but I didn't want to just assume anything or re-invent the wheel which is why I figured I'd just ask you guys. I've searched and searched the forum to find these anyswers, but anything that got me close was a broken link.
I'm planning on building a pretty standard unit for my first build: Chef's control/main board with turbo & CRC boards. No high pass filter (for this one, but going to on the next). Using the behringer 1mA meter. I'd like to make the turbo switchable so will be using an 2 illuminated pushbuttons (one for turbo, one for bypass), and a front panel Power Button with seperate LED. My questions are:
1) As far as I can tell there's no provisions to power the LED's on the pushbuttons, I will need a small power supply and pull the power for that off of the transformer output. It looks like alot of people are doing this. Does anyone know where I can find a schematic for the power supply circuit?
2) Far as I can tell there's nowhere to wire in a pushbutton power switch on the control/main board, but there is a "power on" LED wiring point on the control board, correct? If that's so, no big deal, I can just daisy chain the line-in wires to a 2A switch, but I just wanted to be sure.
3) I've seen some guys use the bypass switch to control a relay to do the actual audio bypass. I would like to do this as well. Does anyone know what I should do here or what to use?
4) Can anyone recommend a transformer? Digikey is out of the "Amveco Magnetics 62063" transformer and they don't have an exact equivalent. Mouser is pretty much useless.
5) I'm going to use the THAT2181AL08-U Trimmable VCA's for the audio but it looks like I have to use the 2180 "Pretrimmed" VCA's for the sidechain and turbo board, correct?
