byoung
I'm trying to calibrate the unit right now....this may seem like a dumb question.... ok very dumb...but I've got to ask.....when attching the DMM to the inputs or outputs on the balanced lines.... I attach the leads to + and 0, or - and 0 or across + and - ? I knew this at one time but can't find what I did with my notes. I've been doing + and 0 and when adjusting the GR meter tracking 50mV In is nice and stable but I can't get a stable 50mV on the outputs, it's jumping around 48-59mV without me doing anything, which has led me to think I've got the DMM hooked up wrong.
EDIT: OK I went through the process and followed Gyrafs instructions using my DMM on + and 0 leads. Now the last step was to reset GR meter zero so I did that. And now running the same signal that I just adjust as -6db, the meter is only at -2 on the VU...is this correct?
