jazzcrisis
I'm experimenting with some push-pull tube circuits and have a Collins 6R built up on the bench. No matter what value cathode bypass capacitor I use, I can neither measure nor hear any effect on gain or frequency response when comparing bypassed versus un-bypassed cathodes. The stock circuit uses 20uf capacitors but I've also tried 470uf and 47uf which are oriented capacitor positive to cathode pin and negative lead to ground. I've tried cap vs. no cap on both tubes, and each one separately. Measurements with an HP 8903B audio analyzer show the exact same frequency response + gain and signal level doesn't have an effect either. I also played some music through the circuit and did a null test with capacitor connected and disconnected--result was nearly a full null.
What gives? Are there operating conditions or circuit topologies that will make cathode bypassing ineffective?
