Work out the voltages at the +ve & -ve inputs of the 5534 using its input current.
You mean that maybe it should be reversed, maybe not, right?
You should work this out for ALL your designs .. but for this one C3 should be reversed.
- The input bias through R1 puts the +ve input of the 5534 at a -ve voltage. Assuming no DC on the pot, C1 is the right way round.
- This -ve voltage is reflected on the -ve input on the 5534. So C3 is the wrong way round
- The input bias for the -ve input is via R2. Because it is smaller than R1, there is less voltage across it so the output will be slightly -ve.
- For small output offset, you need R1 & R2 the same.
