Samuel Groner
Hi
Not directly audio related, but I hope to get some expertise here nonetheless.
While searching for low noise chopper amplifiers I came across a design by Jim Williams which claims 40 nVpp (0.1-10 Hz). There are at least four different implementations published but let's focus on this one: LTMag-V16N01-11-FETAmp-Williams.pdf.
I'm puzzled about how this very low noise figure is achieved. The text notes that This low noise is attributed to the input JFET's die size and current density. Or in other words, attributed to the low voltage noise of the LSK389. But--there is a ~10k feedback network (at the output of A1) right in series with the JFET. Doesn't this entirely spoil any attempt for low noise..? And then there's a 3k in series with the input. My calculator says 22.1 nVrms for a 9.9 Hz ENBW, so easily enough to prevent 40 nVpp overall performance.
Let's say the 3k is just a typo (other implementations show anything from zero to 300 Ohm). But what about the feedback network? I realise that a chopper amp has special properties regarding 1/f noise, but if the 10k feedback resistor doesn't contribute noise why should the JFETs? Any help?
BTW, any pointers to other interesting (discrete) chopper schematics welcome!
Samuel
Samuel
