circuit recommendations for neuman M7 capsule
MLM
hi there! i just got given a Neumann M7 capsule (the one that plugs into the top of a mic such as the blue bottle). On the box it states that the capsule is for the CM7151 microphone - I was wondering if anyone has any suggestions for a more up-to date circuit I could use that uses tubes/transformers that are still easily obtainable? Any help wld be most gratefully recieved! Cheers!
The G7 circuit :)
Or Oliver Archute's U 47 with ef 80 tube.
Maybe Gus' Brauner VM-1
Hmm... anyother ideas???
How come there isn't a circuit with a RCA 5693 tube around these parts :(  I see skylar's body uses one and I searched a bit... also, check out the microphone META... lots for really cool things there :D
will check out the mic meta right now! cheers for the info, will check out everything u mentioned. :)
