SIXTYNINER
Ok ,Exactly my point.
but they only need to replicate , put on air , pre created sound ....
something like reheat an already prepared dish .
No, sound designers, foley artists, etc.. do not only just replicate. Audio is much more than recording music.Ok ,
And maximum respect for each of those who work there !!Live broadcast is the most hectic environment I’ve ever witnessed in audio. Everything doesn't need to be 'perfect' like in music recording. You only get one shot and there are incoming audio assets flying left and right. It's a very demanding job.
But what does it have to do with the fact that in the studio as in mastering
the need is outboards that will help improve the sound
for make it more musical and pleasant to listen ,
Classical music still uses analog outboard in many cases (ask GML) and it is all clean, the same thing applies with many Jazz genres, folk, world music, etc.... many of those artists do not want colored gear and do not use 100% digital. When I worked in a major radio station, they had 3 recording rooms, one was big enough to fit in a PA and an audience of a few hundred, and not all was digital and it wasn't that long ago. Foley recording artists, not always use 100% digital gear, sound designers, for instance for movies, do not always use 100% digital gear.Do you mean that Music is now produced and mastered
in Broadcasting tv and radio stations (where all is digital from years) ,
and on Live stages where also there is all digital from years
without hi end analog outboards
( although when the pa was full analog , however the hi end analog outboards
very little could be seen.... , except in some special cases ) ,
same for almost all the theaters ....
Are you sure that it is not the exact opposite ?You are only focusing on a particular genre when you say that only colored gear makes sense, and you are making generalizations.
Perhaps you could care to answer the question I've been asking you repeatedly since the beginning and which you have neglected to give a straight response: What exactly does 'musical' means when it comes to a pro audio device? Please, do not just answer with another question like asking me if I hear the difference between a Strat and a Squier, or with anecdotes of people you know, just tell me, what exactly is 'musical' when related to a pro audio device? that would be enough for me to know, however, if you care to answer more questions, I also would like to know other things related to your original post.Are you sure that it is not the exact opposite ?
(i know very well the "G.M." recording method / concept ,
consisting of recording the "sources" much natural as possible ,
to have subsequently much room as possible for intervention ,
but this is about recording ),
I know various Engineers that work for classical music and lyrical artists
( some also very famous artist ) all record same as "G.M." ,
just trying to optimize the type of microphone depending on the instrument ,
for the best possible performance ,
but for the mix, the "concept" is so different .
just to mention one of the various "planets" in the "universe" at random :
Aphex owes much of its market success to his aural exciters / enhancers ,
used by any engineer for many years (and various today too)
to "beautify"classical ( and not ) strings , brasses , also vocal choirs , drums (snare , ride , crash ,hi hat , etc.. ) , gtrs (electric , acoutic and classic) ...... ,
and also but not least on the LR master out processing chain ,
especially the studios (but also live pa)
that could not afford expensive outboards ,
classical and lyrical music apart that is a very little part of global market ,
the :
Rock , Heavy Metal , Blues , Pop , HipHop ,R&B , Dance , Folk ,
Electronic (any kind of electronic) , Funk , Soul , Acid jazz , Fusion ,
but also Jazz (and not only on the Rhodes piano) ,Reggae , Ska ,
and so many other type of music ,
put chorus , phaser , flanger , (also analog like vintage Roland) ,
any kind of distortion also a cobination of (and not only on gtrs) ,
and other more ... ,
also reverbs ( as also John Roberts mentioned above) are equalized
with normal or tube eq for add to the tracks more "vibes" .
that the clean and transparent outboards (& plug ins) cannot .
I missed the joke emoticon... an insulting joke is still an insult.Oh, come on John. It's a joke.
umm You and Ricky?It's hard to tell jokes these days, as even Ricky Gervais found out.
True...The fool often tells the truth. And fools have been allowed to do so for millenia.
Maybe if it was funny?
[edit- nah, not even if it was funny, still unkind /edit]
...Really it is so difficult ?- Which criteria should be met to determine if a pro audio device is more or less musical?
It is so easy that you can't even define exactly what it is, yet you use the term musical like it means something. Sound better also is subjective, I am sure that what sounds good to me doesn't sound good to you, and still I don't know what the term 'musical' relates to all you have mentioned......Really it is so difficult ?
... Could it be the one that at the output simply makes what is fed in at the input sound better ?
