I'm using a laminator to do this, I got it a few weeks ago and seems to be rocking on, few mods, increased pressure, a bit more temp, a few degrees only so nothing to worry about. To clean them I just use fine steel wool, last try was with really nice boards which came pretty clean from the store, so I nearly scratched them and the transfer failed badly, not a bit of toner to the board, that happened with two boards, I give another scratch with the steel wool and the transfer was perfect, wasn't the dirt, just the cooper too smooth. The good thing about the laminator is the easy it is to repeat the process, may change a bit with the board size, but I only had problems with boards which take too long to go through the machine. I managed to make some nice 6mil traces/clearance and some 5 mil traces/clearance, I wouldn't trust the 5 mil clearance but all the other seems to work fine, where just small board to test that. I made a few with 10mil rules and not a single problem with them.
JS
