therecordingart
PCB Making:
So far I've tried the photo method and the toner transfer method using PNP Blue, TTS Paper, photo paper...you name it. For those that want to stick with the toner transfer method I did something today that just rocks and it's cheap!!! I printed the layout onto a magazine page that I ripped from Guitar World. I scrubbed some copper clad board clean, pressed the paper to the board with an iron for 30 seconds, and then ran the pcb through a laminator (same one suggested at pulsar.gs). I then threw the board in the freezer for about 5 min then threw it in hot soapy water for 20 min. Peeled the paper, rubbed off the stuff that is stuck with my finger, and there you go. A PCB that is nicer than both PNP and TTS, and about 99% as good as the photo method. I ended up running off 10 PCBs today and only had to re-do one because I was rushing and screwed up.
Desoldering irons:
I suck at desoldering and I'm modding an Alesis 3630. I can't afford a nice vacuum desoldering station so I ran to Rat Shack and spent $10 on their desoldering iron. Wow! It blows the socks off of just using the bulb that they sell. Much nicer than wick as well. I was removing ICs and VCAs without cutting the legs.
Desoldering irons:
