JohnRoberts said:At some point we should take a step back and ponder why we are essentially redesigning a product years after it has been put into service. Were these PS always a hot mess, or has something degraded? In my experience caps fail or they don't. If you suspect the caps, such faults will usually reveal in a visual inspection. Look for swelling or leakage. Sometimes if they are left powered off for very long periods of time, they may need to be re-formed in, but I'm talking sitting for years not days.
That's exactly what I was thinking.
I don't have the PSU at hands right now, but I remember looking at the caps and I'm pretty sure they looked ok. I'm also quite confident that when I check them with a dmm I'll see a normal behaviour - that is initial 0R resistance that is slowly rising up to infinity. Otherwise (if they were failed shorted) the PSU won't work at all. So I'm not really sure how to check them if they are still any good.
When I had that beast at home, I started it slowly with variac and had no problems whatsoever.
Replacing all caps is quite expensive - they run up to 70$ each, and there're 4 of them. So this brute force approach is reserved as a last resort.
I've also found a 200A diode bridge that I can get locally (around 60$), as well as semikron diodes mentioned by analogguru (approximately 50$ each). But installing these looks like a bandaid. So I really need to find a way to check the caps reliably. I'm planning a trip to the studio tomorrow, will see what I find.
