RuudNL
In case the amplifier input in unbalanced. And is amplifying the 'wrong' (FET source) signal.Would you like to point out a 'real life' case where this is a disadvantage?
I already confirmed the solution you suggested works.Why don't you make something with my method first? It's easy. Then you have a baseline to see if you can do better.
For low frequencies, the FET would then act as a phase splitter, but for high frequencies the FET would act as a source follower:
This works. Disadvantage is that the attenuation of high frequencies only works on one 'leg' and that the maximum attenuation can be no more than 6 dB.
