innercityman
After some inspections, I saw a short between my left out connection and one solder pad of the IC just near by (I took my out connections where the 100p cap's legs were lifted)
In fact after referring to the GSSL layout, I realized that it was not a short, the solder pad where the 100p cap leg is lifted has to be connected to one solder pad of the 5532 IC. So this is a wrong way to explain the issue. Just in case, I changed the place where were solded my out connections as you said in your guide that there is no matter which one of the 2 left holes you use for it, but I'm afraid that this doesn't change anything. So I'll wait for your answer before trying a new test.
One more question though (maybe stupid)... On your wire guide, only the left and right signals for wet, dry and out are connected. So what about the 0 point which is the ground right ? following your guide, I connected the ground for the 15 and 12 volts only. The ground for 15v is connected directly to the chassis of the unit, and the ground for 12 v is connected to the Ov pad on the GSSL just beside of the +12v. So I've just cut the O points (brown) wires. Is it ok with that ?
