[quote author="radiance"]Well, it's more the never ending quest against caps in the signal path. But than again...this crush/blend thingy will probabely be used with a GSSL comp which does have caps so what gives.....This is probabely a stupid guess..but....is it possible to add some sort of servo circuit to a line receiver like used in this circuit?? Or more specific: What else can be used for DC blocking after a line receiver? I've seen circuits where none was used, no caps, nothing.[/quote]
Of course it also depends on the amount of fiddling you're expecting to do. But a blend-control it won't be rare that an adjustment is to be made.
Up to the user/builder to decide if he/she is willing to put up with eventual little pops. Or just try it: measure the DC across the control, skip the caps, listen.
Using a servo here would be overkill imho, easier alternatives are to use big film-caps in the 'direct' signal path* and/or trim offsets. And/or tweak raise impedance-level a bit to reduce the value of the film-caps.
(*: as opposed to using ehh, again film caps in the 'indirect' signal path of a servo)
Proost,
Peter
