Gold said:
Two words I will not soon forget: Cable Capacitance.
I replaced the input and output pots with trimmers mounted on the board and the frequency response is now flat to 20k. I was planning on making this a one knob compressor anyway. I am building four channel units so I have the boards mounted with the PS section towards the rear of the case. I probably have a longer run than most to the front panel.
My DAOC had quite the roll of on the high end, starting at 2k and was about 3dB down around 16-20kHz.
I tried a few things, and even running unbalanced without transformers it still had the roll off.
I messed around with different value output caps, and that made no difference....................
So I took some advice from Gold's post, and jumpered some pots to see what would happen.
Nothing really changed much when I jumpered the input pot, but left the ouput pot. Maybe 1/2 a dB better.
But when I jumpered the output pot, but left the input pot, it measured nearly ruler flat frequency response ;D
But why would this happen?? Cable capacatance?? I don't really understand it, or why it only seems to effect this project.
Other projects have cables all over the show, and have great frequency response.
This is my first valve comp, so maybe I'm missing something.................
A lot of people mention how it sounds very warm,analog, smooth on the highend......... Maybe it's this roll off from the output pot that they are hearing? Mine sounds very clear and crisp now.
What's the best way to get around this? Having the output pot is very useful, but it messes my sound up???
Btw I've got most of the Kubi mods on mine. All but the step up transformer, or the changed output cap
