loads of people didn't increase Cx04 and are happy1. Does it mean that if I install 2 vactrols more I don't need to increase the Cx04?
good luck2. Do I need to compare vactrols?
haven't tried one, but why not?3. Can I use the Lundahl LL5402 as output trafo?
I would leave all resistors like they are. even kubi didn't any change there"3) (Forrsell only and unconfirmed, as it seemssomeone suggested raising the 4.99k and 1k resistors (series and shunt) to 49k and 10k before the opto's resistor (here in series, see schamatic) to reduce difference between individual optos. ."
Ciao Silent:art
do you think can help me to better match the opto?
can create problems forD-AOC?
I didn't match the T4b's (since I only have two of them :green: )[silent:arts] said:[quote author="hejsan"]Have you checked if the matching is satisfactory? Did you somehow match the t4b's?
The resistors are used to fix the load on the opposite side of the transfo... The 10k fix a minimum load of 600 (if wired 1:4) on the input. As you may plug your gear to a 10k load, the 2k2 fix the proper load on the tube side. If not the reflected load of the tube would be 40k. It's not a real problem but some tube arrangements are sensible to that kind of load changes...dingo said:hello SOEREN!
I have wired the in and out trafo like in the gyraf pulteq eq
sound great no bass lost
i am not using r 10k on input trafo and 2,2k on out trafo for the moment
i am not shure how effective they are?
maybe someone can help on the resistors utility ?
dingo.![]()
lolo-m said:The resistors are used to fix the load on the opposite side of the transfo... The 10k fix a minimum load of 600 (if wired 1:4) on the input. As you may plug your gear to a 10k load, the 2k2 fix the proper load on the tube side. If not the reflected load of the tube would be 40k. It's not a real problem but some tube arrangements are sensible to that kind of load changes...dingo said:hello SOEREN!
dingo.![]()
I hope I'm clear because I'm really tired :-\.
dingo.![]()
Soeren_DK said:Where should the resistor be placed for the output trafo? Should I change a resistor on the board or is it something to add directly on the 5402 trafo?
Søren
flintan said:Could someone confirm to a colorblind that the one with dual vactrols is the most sensitive curve in this plot? :-\
http://www.silentarts.de/DIY/D-AOC/KubiMod.GIF
