I made the transformerless inputs yesterday. When you connect them, the input trafo secondary is completely bypassed. Wow !
I like this comp so much more now. My slight mismatch between channels, was due to the Edcor inputs. I felt that my DAOC´s threshold was a bit too sensitive, but now, and due to the fact i´m going unbalanced instead 600:10K, i have a more manageable threshold range.
Also, i bypassed the 22u solen fast caps with .1 ERO MKP1840.
I don´t feel the need for the lundahls or whatever nice input trafo right now.
I think i´m leaving my DAOC this way. I´m keeping the edcors for balanced input, but, i think the unbalanced inputs are keepers. My cable runs are usually short.
Should i post this on the main DAOC thread ?
Silvas said:Hello
I've been enjoying my DAOC for a few months and it is a superb compressor on almost everything i throw on it. I still have a question regarding the stereo link...Is there some way to adjust the stereo match as in the D-LA2A ? I'm using the DAOC all the time in dual mono (on stereo material) without any troubles and the matching and metering is great, but as soon as i link the channels, there's a mismatch of a few dB's (GR tracking remains accurate, tho).
Any ideas of where i can start looking ?
Also, i have a very very small difference between channels (0,6dB) without any compression, and i'm using rotary switches...which will be a good point to fine tweak the gain a bit to compensate ? (just for peace of mind)
I was looking at the schemo, and i was thinking, maybe i can tweak the 470k feedback resistors in the output (or input) stage to fine tune the gain ? or there's a better way? (the 49,9k grid resistors?)
Thanks so much !
jensenmann said:Silvas said:Hello
Thanks so much !
I have the same stereotracking problem. I did swap many sidechain tubes, all the resistors in the SC are within 1%, measured levels over there are fine, so it seems that the only remaining source of trouble are the optos. The datasheet states a tolerance of 25%, yuk. Matching these would be pretty expensive and a labour of love. Too bad that I didn´t realize that earlier. Now I have built it as stereocomp but in that way it´s not usable for me. In dual mono everything´s fine, though. Now I have a useless stereolink button on the frontpanel that makes me angry every time I see it.![]()
(abridged)Silvas said:I posted this on some topic on "Studio A". I think it's worthwile to paste it here.
Anyone else running this baby on unbalanced inputs?
Script said:As the optos seem to have 25% tolerance (örps) and we don't want to buy 10 optos or so to find a close enough match, would putting a multi-turn trim across the opto's resistors (the ones near the input) make sense to match their range?
Script said:Sounds good. Does that mean simply bridging the transformers or is there an input buffer involved? If so, what does it look like? Maybe it could even be switchable?
s
