mata_haze
shabtek said:Mata, sell the ha100x get some nice 1:2 hi-z input iron.
Are you serious?
Eje2005 said:ilfungo said:I've Kubi mod with 2 vactrol ???
Ok, i removed my kubi mod. Too much for me.
But try the trimmers on the kubimod, Start with Anode on the first one then add a trimmer to the cathode on the second vactrol, if it dosent work switch the second trimmer to the anode instead.
Its a couple of minutes of work but all worth it.
Like silent:arts said, should also work with resistance on the stereo link. But i´m not sure on this.
Eje2005 said:Silvas, you removed the kubi mod?
Dont know about the trimmer on the stereolink, could be worth a shot no?
If it doesnt work just lift the vactrols. Really simple.
ilfungo said:ciao Silvas
I also love the Kuby mod ....
I tried to insert a trimmer on stereo link
I can improve things but not completely fix ...
I do not know if it makes sense to try two trimmer .... ???
Eje2005 said:ilfungo said:ciao Silvas
Two trimmers on the stereolink makes no sense to me.
Did you try to put the trimmers on the anodes of the vactrols? In not, why? Works perfect here.
I had ~2dB difference between the channels, easy fix with the trimmers. I might try to go back with dual vactrols since i can easy lower the compression with the trimmers.
Silvas said:Eje2005 said:ilfungo said:ciao Silvas
This will screw up my nice matching when unlinked ???
Do you mean one trimmer on each anode ? 4 trimmers using kubi mod ?
ilfungo said:sorry does anyone know how to connect correctly true bypass relay board? ???
+ 24v to switch and after to the board
- To board
G on board to main ground
is that correct?
thanks
