tzman
zayance said:Finally had time to finish the late Christmas present i made myself, wanted to make it look fancy for my first Tube project, i think that's mission acomplished, but don't know if i'll do on my next build tough :. Had some tiny issues but all is good.
I got to thank Volker and Analag for the project, Franck @NRG for all the panel work Danke Schoën to you guys i'll have an Augustiner on this one, PROST!
Also like to thank Mad.Ax for his help and clarifications (merci monsieur) and all of you guys here for the inspiration and help also, without the forum i wouldn't even have tought about all this.
On quick sound check, i was pleased by the sound and compression, i'll use it as is for some time and tweak on taste, i just have a low HT when all tubes are in 188V at R128 ???, but all works as expected, all matched as possible etc....
Nice!
I see you're using SCR Audio caps, right?
What value did you use for Cx04? And what exactly did you use for the curve mod? Blue LED's, double vactrol?
Cheers!
