Hi... I just got my D-AOC working and I have a few questions about the power supply.
My Edcors are in the mail so I set it up without transformers. It sounds REALLY great. Frequency response is nearly flat to 20Khz. There is distortion but I like it. I think it might be worth keeping it this way as a "color" box.
I'm using half of a 250-0-250 toroid. It is actually giving me 270vac. I have 325vdc before R1 and 302vdc after R1. I have 258vdc after the vreg and end up with 248vdc after Rx28.
The vreg heats up to around 120F (49C) but R1 is 170F (77C) or more. I guess it's all within the specs, but I'm worried about R1 (470R 2W). Should I replace it with a 3W or even 5W resistor? Should I use 500R or higher to bring down the voltage into the vreg?
The voltage spikes up to around 295vdc before settling down to 248v. Is that normal?
Also, I'm using AC for the heaters, which seems to work fine (self noise is -82db). The transformer is rated for 2A, so I wonder if I am leaving enough overhead if I'm using 1.8A for the heaters? I'm running the lights off the 5v winding.
I'm looking forward to hearing the difference the transformers make. But for a budget build, doing this with AC heaters and no transformers still makes a pretty great box.
